Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1130 Screen Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 2, imagem 1 %32
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 3, imagem 1 %32
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 4, imagem 1 %32
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 5, imagem 1 %32
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: passo 6, imagem 2 %32
    • Remove six 7mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 7, imagem 2 %32
    • Remove two connector cables.
    • Separate the two unhinged parts.
  8. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 8, imagem 1 %32
    • Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Remove the two 6mm screws.
  9. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 9, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 9, imagem 2 %32
    • Use the black nylon spudger to remove the long plastic covering underneath the screen.
    • Remove three 6mm screws.
  10. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 10, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 10, imagem 2 %32
    • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  11. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 11, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 11, imagem 2 %32
    • Peel off tape and remove the cable.
  12. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 12, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 12, imagem 2 %32
    • Remove the connector chip.
  13. Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 13, imagem 1 %32 Lenovo IdeaPad Flex 4-1130 Screen Replacement: passo 13, imagem 2 %32
    • Peel tape and remove cable underneath.
Conclusão
Adrian Miranda
Membro desde: 02/15/18
677 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S17-G5, Boczar Spring 2018 Membro de USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 1,702
