Ir para o conteúdo principal
Lenovo IdeaPad 730S 13IML/IWL Battery replacement
O que você precisa
  1. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: passo 1, imagem 1 %32 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: passo 1, imagem 2 %32
    • Start by taking out your Torx T4/5 bit from your iFixit-kit to do this. It's unfortunate companies like Lenovo have to use these kinds of screws.
    • Unscrew the 9 Torx and T5 screws from the bottom.
  2. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, imagem 1 %32 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, imagem 2 %32 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, imagem 3 %32
    • Pry the back cover open with an opening tool.
    • After you have the back cover off, you have access to the battery and all the other components.
    • Use a Phillips 00 bit to unscrew the 2 screws holding in the battery. Then remove the connector gently.
  3. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: passo 3, imagem 1 %32 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: passo 3, imagem 2 %32
    • Un-route the speaker wire, as when it comes to pulling out the battery, the speakers will get caught/possibly break if this isn't done.
    • Check that no other wires are tangled on the battery.
    • After doing so, gently pry out the battery until it comes free.
    • It may be wise to re-apply the thermal paste on the cpu, as it'll help it's thermal performance. To do this, loosen the 4 screws around the cpu, and 2 around the fan with a Phillips 00 bit.
Conclusão
To reassemble your device, follow these instructions in reverse order. Happy computing!
Nick P
Membro desde: 01/17/22
1.672 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 28
Duração total: 2,662
