Ir para o conteúdo principal
Lenovo IdeaPad 720S-13IKB GPU Fan Replacement
O que você precisa
  1. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove back cover: passo 1, imagem 1 %32
    • Power off Device
    • Remove charger
    • Remove 6 T5 Screws
    • Remove 4 T5 Screws (These Screws are at an angle)
    • Remove the back cover using opening Pics. Start at the back(where the screen is)
  2. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: passo 2, imagem 1 %32
    • SSD/DisplayConnector Cover
    • Battery
    • M.2 Wifi&Bluetooth
    • Speakers
    • RAM Cover
    • CPU
  3. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Battery: passo 3, imagem 1 %32
    • Unplug battery
    • Remove all 3 Screws using PH1
    • Take out the battery
  4. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: passo 4, imagem 1 %32
    • Fingerprint reader
    • Touchpad
  5. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Covers: passo 5, imagem 1 %32 Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Covers: passo 5, imagem 2 %32
    • Remove Screws with PH1
    • Remove Screws with PH0
    • Remove RAM cover
    • All covers are also secured using contact clips (Picture 2). Just pull them out
  6. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: passo 6, imagem 1 %32
    • DRAM (K4aag165wb MCRC)
    • Connector To Display
    • M.2 SSD
  7. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Speaker: passo 7, imagem 1 %32
    • Unplug Fans
    • Disconnect Fingerprint and Touchpad
    • Take out Speakers
  8. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Motherboard: passo 8, imagem 1 %32 Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Motherboard: passo 8, imagem 2 %32
    • Remove screws using PH0
    • Remove screws using PH1 and take m.2 parts out
    • Dissconnect cables
    • Disconnect Display Cable
    • No Idea how to connect Display Cable (Tips welcome)
    • Push Moterboard to the left and take it out.
    • At the USB-A Port is some cushion to keep the Motherboard in place.
  9. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: passo 10, imagem 1 %32
    • Remove Fan Connector
    • Remove Screw using PH1
    • Take fan out
Conclusão
Hinomi
Membro desde: 05/08/24
325 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 10
