Ir para o conteúdo principal
Lenovo IdeaPad 5 15ITL05 Battery Replacement
O que você precisa
  1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: passo 1, imagem 1 %32 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: passo 1, imagem 2 %32
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, imagem 1 %32 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, imagem 2 %32 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, imagem 3 %32
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: passo 3, imagem 1 %32 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: passo 3, imagem 2 %32
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: passo 4, imagem 1 %32 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: passo 4, imagem 2 %32
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the battery: passo 5, imagem 1 %32
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 6 Remove the battery: passo 6, imagem 1 %32
    • Remove the battery.
Conclusão
E N
Membro desde: 11/21/22
449 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 80
Duração total: 563
