Introdução
Use this guide to remove or replace the back (bottom) cover on your Lenovo Ideapad 5 15ITL05
O que você precisa
Use a T5 Torx driver to remove nine screws securing the back cover.
The three screws on the hinge side will be longer.
The back cover is held on by plastic tabs around the entire perimeter of the cover.
Use plastic pry tools at the seam. I like to start near the hinge.
Once all the tabs are loose, you will be able to remove the cover.
Uma outra pessoa concluiu este guia.
