Ir para o conteúdo principal
Lenovo IdeaPad 330S-14IKB Battery Replacement
O que você precisa
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 2, imagem 2 %32
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 3, imagem 1 %32
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 4, imagem 1 %32
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 5, imagem 1 %32
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 6, imagem 2 %32
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 7, imagem 2 %32
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 191
