Introdução
When a Hard Drive is failing us or we ran out of storage. The proper fix to all those problems are replacing the HDD. if have an exciting back up in the old HDD please relocate it or use it to restore all data to the new HDD.
This Laptop contain a battery that not easily removable and will require opening the device. I will recommend to turn off the laptop disconnect from the power cable and wait 5 minutes before proceeding the repair.
I will advice if you live in a rich ESD environment to use a ESD protection.
O que você precisa
I will recommend all screws to seal with thread locker so they will not open.
I chose WD because they will give you the option to download a free copy of Acronics True Image WD edition.
5 outras pessoas executaram este guia.
