Ir para o conteúdo principal
Lenovo IdeaPad 330S Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 330S Hard Drive Replacement, Removing bottom case: passo 1, imagem 1 %32
    • Remove 10 screws as shown in picture.
  2. Lenovo IdeaPad 330S Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a plastic pry tool to open the device by sliding it gently around the laptop
  3. Lenovo IdeaPad 330S Hard Drive Replacement: passo 3, imagem 1 %32
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  4. Lenovo IdeaPad 330S Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the screws as shown in picure make sure to replace to 2.5 philips when opening the screw in yellow mark.
    • Remove the black heat shield.
  5. Lenovo IdeaPad 330S Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the two screws as Shown in picture.
    • Pull the hard drive gently towards down the laptop
  6. Lenovo IdeaPad 330S Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the four screws as shown in pictures and remove the drive form the hard drive case.
Conclusão
I will recommend all screws to seal with thread locker so they will not open.
I chose WD because they will give you the option to download a free copy of Acronics True Image WD edition.
6 outras pessoas executaram este guia.
Ilia Tocheny
Membro desde: 04/30/19
1.667 Reputação
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 109
Ao todo: 7,951
