Introdução
Sometimes the cooling solution of a laptop is not working properly due to a faulty fan', a clogged thermal unit or dried thermal paste this guide will show you how to remove the fan, thermal unit so you can get 100% efficient cooling system
O que você precisa
Turn off the device and disconnect from the power.
Remove the 10 screws as shown in picture.
Using a plastic pry tool remove the bottom case (gently).
Using a spudger gently push the black connector to the left (red circle).
If you want to remove the battery by removing the five screws labeled in blue.
Remove the 3 screws that are circuled in blue. Then remove the red one.
The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
Remove the black shield
Remove the two black screws that are marked in red
Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
Remove the 6 screws in revrse of the number stated on screws.
Replace the thermal paste with a fresh one
Removing the fan is not needed but will help with easier dissemble of thermal unit
3 outras pessoas executaram este guia.
2 comentários
Good question, you could try at your local Lenovo Service provider.
