Ir para o conteúdo principal
Lenovo IdeaPad 330S Fan and Thermal Unit
O que você precisa
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: passo 1, imagem 1 %32 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: passo 1, imagem 2 %32
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: passo 2, imagem 1 %32
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: passo 3, imagem 1 %32 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: passo 3, imagem 2 %32
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: passo 4, imagem 1 %32
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: passo 5, imagem 1 %32
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
Conclusão
3 outras pessoas executaram este guia.
Ilia Tocheny
Membro desde: 04/30/19
1.616 Reputação
Autoria de 9 guias
2 comentários
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - Responder
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 1,589
