Introdução
This guide is intended for use on the Lenovo IdeaPad 330-15IGM. The motherboard is the main circuit board in general-purpose computers and other expandable systems. It helps allows communication between many of the crucial electronic components of a system, like the central processing unit, and memory and provides connectors for other devices you may use. In case of issues try running a diagnostics by going to Lenovo vantage, selecting hardware scan and running a quick scan and press begin.
O que você precisa
Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
Remove four 6.8 mm screws that hold the heatsink component into the chassis and motherboard by using the Phillips #00 screwdriver.
