Ir para o conteúdo principal
Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement
O que você precisa
  1. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 3 %32
    • Remove the two Wi-Fi card's connections by gently lifting up on the connectors.
  4. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Remove the single Phillips #0 screw securing the Wi-Fi card.
  5. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Slide the Wi-Fi card out of its port on the motherboard.
    • Do not worry about the angle the card sits after removing the mounting screw - this is how it's meant to be connected and will have to be connected similarly during reassembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 251
