Ir para o conteúdo principal
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
O que você precisa
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: passo 1, imagem 1 %32
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 2, imagem 2 %32
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: passo 3, imagem 1 %32
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 4, imagem 1 %32
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 5, imagem 1 %32
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: passo 6, imagem 1 %32
    • Gently remove the WLAN card out of its slot.
Conclusão
3 outras pessoas executaram este guia.
Ammar Dodin
Membro desde: 01/19/17
1.057 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team 1-3, Rodger Winter 2017 Membro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
Membros da 4
Autoria de 6 guias
3 comentários
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - Responder
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 2,798
