Ir para o conteúdo principal
Lenovo IdeaPad 300-17ISK Keyboard Replacement
O que você precisa
  1. Lenovo IdeaPad 300-17ISK Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, imagem 3 %32
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 3, imagem 2 %32
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
Conclusão
3 outras pessoas executaram este guia.
Ammar Dodin
Membro desde: 01/19/17
1.057 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team 1-3, Rodger Winter 2017 Membro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
Membros da 4
Autoria de 6 guias
Um comentário
thank you so much very help full
deepak - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 5,580
