Ir para o conteúdo principal
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: passo 1, imagem 1 %32
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 2, imagem 2 %32
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 4, imagem 1 %32
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 5, imagem 1 %32
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 6, imagem 2 %32
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 7, imagem 2 %32
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Conclusão
10 outras pessoas executaram este guia.
Ammar Dodin
Membro desde: 01/19/17
1.057 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team 1-3, Rodger Winter 2017 Membro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
Membros da 4
Autoria de 6 guias
3 comentários
Clear and easy - thanks!
Beth Pierce - Responder
Very good and to the point
al_stewart - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Duração total: 9,765
