Introdução
This guide demonstrates how to replace a faulty, damaged, or corrupt SSD in your Lenovo IdeaPad 3-15IGL05.
Hard drives are commonly a point of failure in electronic devices, and replacing one is a relatively simple procedure if done properly.
This replacement will take about 20 minutes, but it can be completed much faster than that if you know what you’re doing.
O que você precisa
Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
