Introdução
Use this guide to replace the Heat sink and thermal paste in your Lenovo IdeaPad 3-15ADA05. Please refer to the troubleshooting page to ensure the heat sink or thermal paste is the problem. Before removal, ensure the device has been powered off.
O que você precisa
Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
