Ir para o conteúdo principal
Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement
O que você precisa
  1. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: passo 1, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: passo 1, imagem 2 %32
    • Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
  2. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 2, imagem 2 %32
    • Insert the opening pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 3, imagem 2 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 3, imagem 3 %32
    • Locate the heat sink above the fan, then using a #0 Phillips head, remove the four M2 x 3mm screws holding the heat sink in place.
    • The screws are captive and should stay attached to the heat sink.
  4. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 4, imagem 2 %32
    • Remove the heat sink.
    • Be careful not to damage the processor.
  5. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 5, imagem 2 %32
    • Using a paper towel and rubbing alcohol. Apply a small amount to the paper towel, then remove the remaining thermal paste until none is left.
  6. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 6, imagem 2 %32 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: passo 6, imagem 3 %32
    • Evenly apply a very small amount of thermal paste to the processor (around the size of a grain of rice), then replace the new Heat sink and press down gently.
    • Be careful when reattaching the cooler so as not to damage the processor.
    • Tighten the screws in a diagonal pattern to ensure even pressure and spread of the thermal paste.
Conclusão
Dylan Torres
Membro desde: 02/08/24
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 58
