Ir para o conteúdo principal
Lenovo IdeaPad 130-15AST Cooling Fan Replacement
O que você precisa
  1. Lenovo IdeaPad 130-15AST Cooling Fan Replacement, DVD/CD Optical Drive: passo 1, imagem 1 %32
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 2, imagem 2 %32
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 3, imagem 1 %32
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Cooling Fan Replacement, Cooling Fan: passo 4, imagem 1 %32
    • Before you proceed, make sure your computer is turned off and it is not connected to any power source.
    • Using a Phillips #1 screwdriver, remove 12 6mm screws.
  5. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 5, imagem 3 %32
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 6, imagem 2 %32
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up. Place the panel aside from the laptop.
  7. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 7, imagem 2 %32
    • Gently move the wires wrapped around the fan that run along the left side of the cooling fan.
    • These wires are not connected directly to the fan and should not be removed but simply displaced from their original location.
  8. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, to remove two 4.00mm screws.
    • You will need to save these screws, as a replacement cooling fan does not come with extra screws.
  9. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 9, imagem 1 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 9, imagem 2 %32 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: passo 9, imagem 3 %32
    • Gently use a prying tool to disconnect the cooling fan from the motherboard.
    • After disconnecting the cooling fan, remove the fan from the laptop.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 648
