Ir para o conteúdo principal
Lenovo IdeaPad 130-15AST Battery Replacement
O que você precisa
  1. Lenovo IdeaPad 130-15AST Battery Replacement, DVD/CD Optical Drive: passo 1, imagem 1 %32
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 2, imagem 2 %32
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Battery Replacement: passo 3, imagem 1 %32
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Battery Replacement, Battery: passo 4, imagem 1 %32
    • Before proceeding, make sure the computer is turned off and it is not connected to any power source.
    • Using a Phillips #00 screwdriver, remove twelve of the 6.0mm screws.
  5. Lenovo IdeaPad 130-15AST Battery Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 5, imagem 3 %32
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Battery Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 6, imagem 2 %32
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up.
  7. Lenovo IdeaPad 130-15AST Battery Replacement: passo 7, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove three 6.0mm screws.
  8. Lenovo IdeaPad 130-15AST Battery Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 8, imagem 2 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 8, imagem 3 %32
    • Using a pair of tweezers, remove the black plug which includes 8 wires.
  9. Lenovo IdeaPad 130-15AST Battery Replacement: passo 9, imagem 1 %32 Lenovo IdeaPad 130-15AST Battery Replacement: passo 9, imagem 2 %32
    • Grabbing the sides of the battery with one hand, remove the battery from the laptop.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 7,561
