Ir para o conteúdo principal
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: passo 1, imagem 1 %32
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 2, imagem 2 %32
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 3, imagem 2 %32
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, imagem 3 %32
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 6, imagem 2 %32
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 7, imagem 2 %32
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 8, imagem 1 %32
    • Remove the hard drive from the housing mount.
Conclusão
Cameron Mounce
Membro desde: 09/05/23
668 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-3, Pee Fall 2023 Membro de Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 119
