Ir para o conteúdo principal
Lenovo IdeaPad 110-15ISK Upper Case Replacement
O que você precisa
  1. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Upper Case Replacement: passo 2, imagem 1 %32
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Upper Case Replacement: passo 3, imagem 1 %32
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Optical Drive: passo 5, imagem 1 %32
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Upper Case Replacement: passo 6, imagem 1 %32
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Upper Case: passo 7, imagem 1 %32
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Upper Case Replacement: passo 8, imagem 1 %32
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler
Membro desde: 10/17/18
621 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2018 Membro de UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
Membros da 4
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 2,428
