Ir para o conteúdo principal
Lenovo IdeaPad 110-15ISK Cooling Fan Replacement
O que você precisa
  1. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 2, imagem 1 %32
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 3, imagem 1 %32
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Optical Drive: passo 5, imagem 1 %32
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 6, imagem 1 %32
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Upper Case: passo 7, imagem 1 %32
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 8, imagem 1 %32
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Cooling Fan: passo 9, imagem 1 %32 Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Cooling Fan: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • On the back panel, the cooling fan is located at the top right.
    • Unscrew the 6.0mm screw using the Phillips #1 screwdriver.
    • Push the plastic piece towards the direction the wires are in with the tweezers to completely disconnect it from the back panel.
Conclusão
Uma outra pessoa concluiu este guia.
Jakub Szark
Membro desde: 10/17/18
513 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2018 Membro de UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
Membros da 4
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 1,715
