Ir para o conteúdo principal
Lenovo IdeaPad 110-15IBR Optical Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: passo 2, imagem 1 %32
    • Using #1 Phillips screwdriver remove the 1 (9mmx6mm) screw holding the disk drive in place.
  3. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: passo 3, imagem 1 %32
    • Pull the optical drive away from device to slide out of dock.
    • Careful not to pull the drive straight up or towards the device, otherwise damage might be done to the drive connector.
Conclusão
5 outras pessoas executaram este guia.
Saddam Alsinai
Membro desde: 10/18/17
669 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S3-G4, Liner Fall 2017 Membro de UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
Membros da 4
Autoria de 14 guias
Um comentário
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
Max Härtwig - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 3,669
