Ir para o conteúdo principal
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: passo 1, imagem 1 %32 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: passo 1, imagem 2 %32
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 2, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 3, imagem 2 %32
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 4, imagem 2 %32
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove hard drive from housing.
Conclusão
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14 outras pessoas executaram este guia.
Saddam Alsinai
Membro desde: 10/18/17
669 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S3-G4, Liner Fall 2017 Membro de UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
Membros da 4
Autoria de 14 guias
3 comentários
Unplug or remove battery first?
Chris Quirke - Responder
you do not need to unplug or remove the battery
Holden Phillips - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 40
Duração total: 19,808
