Ir para o conteúdo principal
Lenovo IdeaPad 110-15IBR Battery Replacement
O que você precisa
  1. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: passo 1, imagem 1 %32 Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: passo 1, imagem 2 %32
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Remove the thirteen 9 mm Phillips #1screws.
    • Pull out the DVD drive and unscrew the final 3 wide-head screws holding the back in place.
  2. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove the back: passo 2, imagem 1 %32
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  3. Lenovo IdeaPad 110-15IBR Battery Replacement: passo 3, imagem 1 %32
    • Remove the two 9 mm Phillips #1 screws holding the battery.
  4. Lenovo IdeaPad 110-15IBR Battery Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 110-15IBR Battery Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad 110-15IBR Battery Replacement: passo 4, imagem 3 %32
    • Disconnect the battery cable connector from mother board.
    • Remove battery from device.
Conclusão
16 outras pessoas executaram este guia.
Saddam Alsinai
Membro desde: 10/18/17
669 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S3-G4, Liner Fall 2017 Membro de UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
Membros da 4
Autoria de 14 guias
23 comentários
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
Clarey Ryan - Responder
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Daniel Jansen - Responder
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
charlie.bansj - Responder
I unscrew everything but to open it, it gets stuck in the middle….. i am afraid to pull hard…..
djerro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 44
Últimos 30 dias: 212
Duração total: 46,802
