Ir para o conteúdo principal
Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement
O que você precisa
  1. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement, WiFi/ Bluetooth Card: passo 1, imagem 1 %32
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: passo 2, imagem 2 %32
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: passo 3, imagem 1 %32
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: passo 4, imagem 2 %32
    • Remove the tape and unscrew the single 2mm PH00 screw.
    • Pull out the current WiFi/Bluetooth card, unplugging the two wires connected to it.
Conclusão
Follow the guide in reverse to reassemble your device.
Congratulations on successfully completing the WiFi/Bluetooth card replacement for your Lenovo IdeaPad 100s-14IBR laptop! By following this guide, you've taken a proactive step towards improving your device's wireless capabilities, ensuring a more seamless and reliable connectivity experience.
Remember to power on your laptop and test the new card to ensure it functions correctly. If you encounter any issues, double-check your connections and revisit the steps to ensure everything is in place. Feel free to revisit this guide or seek additional assistance if needed.
Uma outra pessoa concluiu este guia.
Bin Feng
Membro desde: 03/18/19
256 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 26
Duração total: 1,766
