Ir para o conteúdo principal
Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement
O que você precisa
  1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement, USB/Headphones Jack: passo 1, imagem 1 %32
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 2, imagem 2 %32
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 3, imagem 1 %32
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 4, imagem 1 %32
    • Remove the three 4mm PH00 screws.
    • Unplug the ribbon wire connected to the USB/Headphone Jack PCB by lifting the black plastic tab holding the ribbon cable down.
    • Be extra careful not to bend the ribbon cable too much as it is fragile.
  5. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: passo 5, imagem 2 %32
    • Lift the USB/Headphone Jack PCB off of the board gently and put it to the side.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 840
