Ir para o conteúdo principal
Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement
O que você precisa
  1. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement, Hard Drive/ Solid State Drive: passo 1, imagem 1 %32
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: passo 2, imagem 2 %32
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: passo 3, imagem 1 %32
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Hard Drive/ Solid State Drive Replacement: passo 4, imagem 1 %32
    • Remove the solid state drive.
Conclusão
6 outras pessoas executaram este guia.
3 comentários
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
ROBERT GOFFINSKI - Responder
I replaced with an ssd but the laptop is not recognizing it
Janet Zinabe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 119
Duração total: 14,825
