Introdução
This is a guide on how to replace the touchpad on the Lenovo IdeaPad 1 14IGL7. You may need to consult this guide when your touchpad is no longer responsive, and you need to replace it. Please take precaution to not cause harm to the device.
O que você precisa
Remove the six 5.5 mm screws that secure the battery using a Phillips #00 screwdriver.
Remove the three 3 mm screws that hold the metal bracket in place using a Phillips #00 screwdriver.
Quase terminado!
Conclusão
