Introdução
This is a guide on how to replace the fan component in the Lenovo IdeaPad 1 14IGL7. This is a guide if you are needing to replace the fan component on your device, if it is not cooling the device properly. Please take precaution when handling, to prevent damage to the device.
O que você precisa
Remove the seven 5.5 mm screws that secure the fan using a Phillips #00 screwdriver.
Quase terminado!
Conclusão
