Ir para o conteúdo principal
Lenovo IdeaCentre K410 RAM Module Replacement
O que você precisa
  1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: passo 1, imagem 1 %32
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 RAM Module Replacement: passo 2, imagem 1 %32
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: passo 3, imagem 1 %32
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
Conclusão
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
Timothy Grebe
Membro desde: 10/19/14
1.619 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 10-39, Amido Fall 2014 Membro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Membros da 4
Autoria de 18 guias
2 comentários
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Responder
But it is still good to have guides on everything
im glad that ifixit exists
remliv - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,425
