Ir para o conteúdo principal
Lenovo IdeaCentre K410 Power Supply Unit Replacement
O que você precisa
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: passo 1, imagem 1 %32
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 2, imagem 1 %32
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: passo 3, imagem 1 %32 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: passo 3, imagem 2 %32
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, imagem 1 %32 Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, imagem 2 %32 Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, imagem 3 %32
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 5, imagem 1 %32
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 6, imagem 1 %32
    • Remove the power supply unit by pulling away from the screw side and then out.
Conclusão
9 outras pessoas executaram este guia.
Timothy Grebe
Membro desde: 10/19/14
1.634 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 10-39, Amido Fall 2014 Membro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Membros da 4
Autoria de 18 guias
Um comentário
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 4,301
