Ir para o conteúdo principal
Lenovo IdeaCentre K410 Heat Sink Replacement
O que você precisa
  1. Lenovo IdeaCentre K410 Heat Sink Replacement, Side Panel: passo 1, imagem 1 %32
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Heat Sink Replacement: passo 2, imagem 1 %32
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Heat Sink Replacement, CPU Fan: passo 3, imagem 1 %32
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 Heat Sink Replacement: passo 4, imagem 1 %32
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 Heat Sink Replacement, Heat Sink: passo 5, imagem 1 %32
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
Conclusão
Timothy Grebe
Membro desde: 10/19/14
1.634 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 10-39, Amido Fall 2014 Membro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 803
