Ir para o conteúdo principal
Lenovo IdeaCentre K410 CPU Replacement
O que você precisa
  1. Lenovo IdeaCentre K410 CPU Replacement, Side Panel: passo 1, imagem 1 %32
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Replacement: passo 2, imagem 1 %32
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Replacement, CPU Fan: passo 3, imagem 1 %32
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
    Fan does not need to be removed from the heat sink.
    Ken - Responder
  4. Lenovo IdeaCentre K410 CPU Replacement: passo 4, imagem 1 %32
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 CPU Replacement, Heat Sink: passo 5, imagem 1 %32
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
    Loosen these four screws with the fan attached. Unplug the fan from the motherboard and remove the heat sink / fan as one component.
    Ken - Responder
  6. Lenovo IdeaCentre K410 CPU Replacement, CPU: passo 6, imagem 1 %32 Lenovo IdeaCentre K410 CPU Replacement, CPU: passo 6, imagem 2 %32
    • Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
    • Remove the 11 mm screw using a Torx #20 screwdriver.
    • Remove the cover and remove the CPU by gently pulling upward.
    Why not just lift the lever that allows the CPU cover to open to gain access to the CPU? Removing the cover is not necessary.
    Ken - Responder
Conclusão
15 outras pessoas executaram este guia.
Timothy Grebe
Membro desde: 10/19/14
1.634 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 10-39, Amido Fall 2014 Membro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Membros da 4
Autoria de 18 guias
Um comentário
Why would you remove the fan and the CPU fixation bracket when you could just remove the heatsink by unscrewing it and then lift up the bracket lever...
alphaLONE - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 3,808
