Ir para o conteúdo principal
Lenovo IdeaCentre K410 CPU Fan Replacement
O que você precisa
  1. Lenovo IdeaCentre K410 CPU Fan Replacement, Side Panel: passo 1, imagem 1 %32
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Fan Replacement: passo 2, imagem 1 %32
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Fan Replacement, CPU Fan: passo 3, imagem 1 %32
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 CPU Fan Replacement: passo 4, imagem 1 %32
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
Conclusão
Timothy Grebe
Membro desde: 10/19/14
1.619 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 10-39, Amido Fall 2014 Membro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 2,129
