Ir para o conteúdo principal
Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: passo 1, imagem 1 %32
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: passo 3, imagem 1 %32
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 4, imagem 2 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 4, imagem 3 %32
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 5, imagem 2 %32
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 7, imagem 1 %32
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 8, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 8, imagem 2 %32
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: passo 9, imagem 1 %32
    • Lift the hard drive up to remove it from the enclosure.
Conclusão
12 outras pessoas executaram este guia.
Jackson Blake
Membro desde: 01/22/18
1.119 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
Membros da 4
Autoria de 9 guias
5 comentários
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - Responder
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - Responder
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - Responder
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 73
Duração total: 15,957
