Introdução
This requires a Phillips head screwdriver. Be careful not to drop the screws into the rest of the computer.
Peças
Não são necessárias peças.
  1. Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    • Remove the two screws on the bottom of the computer, one on each side.
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
    • Once it has been separated, lift to remove.
    • Remove the four screws that secure the arm stand.
    • Lift up to remove the arm stand.
    • Remove the three screws that secure the fan.
    • Disconnect the fan power cable from the motherboard, and remove the fan.
Conclusão
Jackson Blake
909 reputação
9 Guides authored
Equipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Membros
9 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Todo: 196
