Ir para o conteúdo principal
Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement
O que você precisa
  1. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Stand Base: passo 1, imagem 1 %32
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 2, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 2, imagem 2 %32
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Back Cover: passo 3, imagem 1 %32
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 4, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 4, imagem 2 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 4, imagem 3 %32
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 5, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 5, imagem 2 %32
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: passo 6, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: passo 6, imagem 2 %32
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 7, imagem 1 %32 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: passo 7, imagem 2 %32
    • Lift up to remove the arm stand.
Conclusão
Uma outra pessoa concluiu este guia.
Jackson Blake
Membro desde: 01/22/18
1.119 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 2,524
