Pular para o conteúdo principal
Introdução
This requires a phillips head screwdriver only. Be sure to not drop the screws into the computer.
Peças
Nenhum componente especificado.
  1. Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Remove the two screws on the bottom of the computer, one on each side.
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  6. Once it has been separated, lift to remove. Once it has been separated, lift to remove.
    • Once it has been separated, lift to remove.
  7. Remove the four screws that secure the arm stand. Remove the four screws that secure the arm stand.
    • Remove the four screws that secure the arm stand.
  8. Lift up to remove the arm stand. Lift up to remove the arm stand.
    • Lift up to remove the arm stand.
Conclusão
Uma outra pessoa concluiu este guia.
Jackson Blake
Membro desde: 22-01-2018
924 reputação
9 Guias de autoria
Equipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Membros
9 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 48
Todo: 464
