Ir para o conteúdo principal
Lenovo Horizon 2s Rear Case Replacement
O que você precisa
  1. Lenovo Horizon 2s Rear Case Replacement, Rear Case: passo 1, imagem 1 %32 Lenovo Horizon 2s Rear Case Replacement, Rear Case: passo 1, imagem 2 %32 Lenovo Horizon 2s Rear Case Replacement, Rear Case: passo 1, imagem 3 %32
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Rear Case Replacement: passo 2, imagem 1 %32 Lenovo Horizon 2s Rear Case Replacement: passo 2, imagem 2 %32
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Rear Case Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Rear Case Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Rear Case Replacement: passo 5, imagem 1 %32 Lenovo Horizon 2s Rear Case Replacement: passo 5, imagem 2 %32 Lenovo Horizon 2s Rear Case Replacement: passo 5, imagem 3 %32
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
Conclusão
Uma outra pessoa concluiu este guia.
Zak Kazakos
Membro desde: 09/25/17
320 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G6, Cannon Fall 2017 Membro de USF Tampa, Team S3-G6, Cannon Fall 2017
USFT-CANNON-F17S3G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 992
