Introdução
Bring your two-in-one tablet back to life with a new battery.
This guide will provide step-by-step instruction on how to detach the back panel, which is designed to prevent damage to interior components. For peak performance of this newly replaced battery, drain the device below 10%, then charge up to 100% uninterrupted.
Flip the device so the rear case is facing upward.
With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
