Ir para o conteúdo principal
Lenovo G780 Screen Replacement
O que você precisa
  1. Lenovo G780 Screen Replacement, Battery: passo 1, imagem 1 %32 Lenovo G780 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Screen Replacement: passo 2, imagem 1 %32
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Screen Replacement, Screen: passo 3, imagem 1 %32 Lenovo G780 Screen Replacement, Screen: passo 3, imagem 2 %32
    • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
  4. Lenovo G780 Screen Replacement: passo 4, imagem 1 %32 Lenovo G780 Screen Replacement: passo 4, imagem 2 %32 Lenovo G780 Screen Replacement: passo 4, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
  5. Lenovo G780 Screen Replacement: passo 5, imagem 1 %32 Lenovo G780 Screen Replacement: passo 5, imagem 2 %32 Lenovo G780 Screen Replacement: passo 5, imagem 3 %32
    • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
    • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
    • Be careful not to break the thin plastic cover.
  6. Lenovo G780 Screen Replacement: passo 6, imagem 1 %32 Lenovo G780 Screen Replacement: passo 6, imagem 2 %32 Lenovo G780 Screen Replacement: passo 6, imagem 3 %32
    • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
  7. Lenovo G780 Screen Replacement: passo 7, imagem 1 %32 Lenovo G780 Screen Replacement: passo 7, imagem 2 %32
    • With the back cover being removed from the screen frame, the back cover can be set aside.
  8. Lenovo G780 Screen Replacement: passo 8, imagem 1 %32 Lenovo G780 Screen Replacement: passo 8, imagem 2 %32 Lenovo G780 Screen Replacement: passo 8, imagem 3 %32
    • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
    • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
  9. Lenovo G780 Screen Replacement: passo 9, imagem 1 %32 Lenovo G780 Screen Replacement: passo 9, imagem 2 %32 Lenovo G780 Screen Replacement: passo 9, imagem 3 %32
    • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
    • With the screws removed the screen will be free to be lifted away from the screen frame.
Conclusão
Uma outra pessoa concluiu este guia.
Riley Griffin
Membro desde: 03/25/19
316 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G4, Henning Spring 2019 Membro de IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,004
