Ir para o conteúdo principal
Lenovo G780 Heat Sink Replacement
O que você precisa
  1. Lenovo G780 Heat Sink Replacement, Battery: passo 1, imagem 1 %32 Lenovo G780 Heat Sink Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: passo 2, imagem 1 %32
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: passo 3, imagem 1 %32 Lenovo G780 Heat Sink Replacement, Fan: passo 3, imagem 2 %32 Lenovo G780 Heat Sink Replacement, Fan: passo 3, imagem 3 %32
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: passo 5, imagem 1 %32 Lenovo G780 Heat Sink Replacement: passo 5, imagem 2 %32
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, imagem 1 %32 Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, imagem 2 %32 Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, imagem 3 %32
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: passo 7, imagem 1 %32 Lenovo G780 Heat Sink Replacement: passo 7, imagem 2 %32
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Conclusão
Riley Griffin
Membro desde: 03/25/19
316 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G4, Henning Spring 2019 Membro de IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 610
