Ir para o conteúdo principal
Introdução
This guide gives a step-by-step instructions for the removal and replacement of a CD drive for a Lenovo laptop, model G70-80. Following the directions outlined below should take approximated five minutes from beginning to completion. The end outcome is a working CD drive for the Lenovo laptop, model G70-80.
Peças
Nenhum componente especificado.
  1. Lenovo G70-80 CD Drive Replacement, CD Drive: passo 1, imagem 1 %32 Lenovo G70-80 CD Drive Replacement, CD Drive: passo 1, imagem 2 %32 Lenovo G70-80 CD Drive Replacement, CD Drive: passo 1, imagem 3 %32
    • Locate a Phillips head screwdriver. Use the screwdriver to remove the 2 screws found on the backside of the Lenovo G70-80. Once both of these screws are removed you will be able to remove the back of the laptop.
  2. Lenovo G70-80 CD Drive Replacement: passo 2, imagem 1 %32
    • Next, you will need to locate the CD drive. If you orient the laptop with the hinge facing you, the CD drive will be in the bottom right corner near the battery.
  3. Lenovo G70-80 CD Drive Replacement: passo 3, imagem 1 %32
    • Remove the screw to the left of the CD Drive.
  4. Lenovo G70-80 CD Drive Replacement: passo 4, imagem 1 %32
    • Once all of the hardware in the previous steps is removed, you will be able to pull the CD drive directly out of the laptop.
Conclusão
Reassembly should be equally as easy as the disassembly. Follow the directions step by step in reverse order to reassemble the Lenovo G70-80 with your new CD drive.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 871
