Ir para o conteúdo principal
Lenovo G70-80 Battery Replacement
  1. Lenovo G70-80 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Battery Replacement: passo 2, imagem 1 %32 Lenovo G70-80 Battery Replacement: passo 2, imagem 2 %32
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Battery Replacement: passo 3, imagem 1 %32 Lenovo G70-80 Battery Replacement: passo 3, imagem 2 %32
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Battery Replacement: passo 4, imagem 1 %32 Lenovo G70-80 Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery.
Conclusão
4 outras pessoas executaram este guia.
Um comentário
Very precise instruction, managed to not &&^& it up. Have a nice day good person!! :)
BodoGamer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,572
