Ir para o conteúdo principal
Lenovo G580 Keyboard Replacement
O que você precisa
  1. Lenovo G580 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: passo 3, imagem 1 %32
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: passo 5, imagem 1 %32
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo G580 Keyboard Replacement: passo 6, imagem 2 %32
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: passo 7, imagem 1 %32
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
Conclusão
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 4,383
