Introdução
The fan in a laptop exists to prevent the device from overheating. Overheating can be causes by the following: too many applications running, device isn’t compatible with applications, component failure, etc. If you hear your computer making a clicking noise or if the fan stops working in your device, consider replacing the fan. Use this guide to remove the fan from your laptop.
O que você precisa
Flip your device over so that the back is facing you.
Using your fingers, push the tabs in opposite directions to eject the battery.
Remove the battery from the device.
Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
Remove the back cover from the device.
Once the back panel is removed, remove the two 3.2mm screws using the Phillips #00 screwdriver.
Remove the power supply cord that is going into the motherboard. The colors of the wires should be: red, yellow, brown and black.
Remove the fan from the device.
