Ir para o conteúdo principal
Lenovo G50-80 80E5 Removing top panel Replacement
O que você precisa
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: passo 1, imagem 1 %32
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, imagem 3 %32
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, imagem 3 %32
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, imagem 3 %32
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: passo 5, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: passo 5, imagem 2 %32
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: passo 6, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 6, imagem 2 %32
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, imagem 3 %32
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: passo 8, imagem 1 %32
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: passo 9, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 9, imagem 2 %32
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: passo 10, imagem 1 %32
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: passo 11, imagem 1 %32
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: passo 12, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: passo 13, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 13, imagem 2 %32
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: passo 14, imagem 1 %32
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: passo 15, imagem 1 %32
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: passo 16, imagem 1 %32
    Comprar
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: passo 17, imagem 1 %32
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: passo 18, imagem 1 %32
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: passo 19, imagem 1 %32
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, imagem 3 %32
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: passo 21, imagem 1 %32
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: passo 22, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 22, imagem 2 %32
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: passo 23, imagem 1 %32
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: passo 24, imagem 1 %32
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, imagem 1 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, imagem 2 %32 Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, imagem 3 %32
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: passo 26, imagem 1 %32
    • Top covered removed
Conclusão
12 outras pessoas executaram este guia.
Victor
Membro desde: 10/17/17
1.282 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G6, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 62
Duração total: 7,438
