Introdução
There is also a video guide to help supplement this step-by-step guide
O que você precisa
From the underside of the laptop, press the two battery tabs inward to remove the battery. Lift the battery to remove.
Flip the laptop over, lift the screen and with a plastic spudger begin to remove the keyboard. Start at the top left corner and work from left to right lifting the keyboard. Once the top section is free, lift the keyboard up and away from yourself. Remove the ribbon cable connection and set the keyboard aside.
3 outras pessoas executaram este guia.
